closing in by bowrider
pontosquantos
hello, i am looking for advise on the best way to close in the bow of my bowrider? turning it into a cuddy.
i want to be able to take my 15' boat on the ocean without worrying about waves flooding over the bow.
will 1/2" plywood fiberglassed be strong enough to walk on? what would be the best way to fasten it down?
Re: closing in by bowrider
Ayuh,.... Even with the bow seatin' area closed in, you'd be swamped,...
Ya might wanta trade up to a bigger boat,...
pontosquantos
yea I was thinking the same thing, but I am committed to finishing it. then sell for a bigger boat.
MikDee
Banned
You need a bigger boat! You don't have enough freeboard to go out in the ocean. I wouldn't go out there in less then a 22-24' boat, and then only on a fairly calm day.
greenbush future
By doing this, you most likely will diminish the value, unless you really do it well. A canvas snap in cover will deflect small amounts of water and it's very reasonable. But it's still not a boat designed or big enough for safe ocean use.
pontosquantos
IMAG1006.jpgI'm not worried about devaluing the boat since it cost very little. here is a pic of the cover so far. I am looking for the best way to fasten it down. I'm not sure if fiberglass resin is strong enough or should I use a adhesive with mechanical fasteners?
pontosquantos
sorry about the repeat
jbcurt00
You posted 3 of the same pix
jackd1023
Personally I would make a canvas "snap on" cover. Not permanent , will deflect water without de-valuing the vessel.
MikDee
Banned
Get yourself some stainless, or monel self tapping screws, long enough to go into the fiberglass, and screw down the perimeter of the deck, then just glass in the open area's with cloth, & resin.
greenbush future
That's a quite a bit of glass work, lots of grinding work too I think, but it can be done.
