Clutch DOGGY ate my pinon nut
dsinger
Man that is funny anyway you spin it..8)
Well I found the Clutch Dog was missing a tooth and the pinon nut was eat up a lilttle. What are the odds my pinon gear is still good. I found the piece of the clutch dog and it was still noticable was not eat up that much. What do you think I should do replace the pinon nut and clutch dog or everything.
Joe Reeves
Re: Clutch DOGGY ate my pinon nut
First thing to do is to dismantle the lower unit completely in order to inspect the components, after which you can seperate the bad from the good.
dsinger
Got her all apart the gears look ok but how far does the pinion nut hang past the gear. Since the dog ate its face off
Joe Reeves
I don't understand the question, but you can see the mesh marks on the gear teeth.
If there's any damage to that pinion gear at all, I'd strongly suggest you replace it. Unfortunately the pinion and forward gear are a matched set.
DHPMARINE
The dog can't touch the pinion nut.PERIOD.!!!
But we do have to figure out what happened.My guess is the retainer spring on the clutch dog came off,the pin came out,and had it's way with the gearcase.
DHP
dsinger
No the spring was good the tooth off the clutch dog got the pinon nut. So I can not find a pinon gear its self/
tashasdaddy
as Joe said the pinion and forward gears are a matched set. you need both.
Joe Reeves
What is the model number of that engine? We would like to know exactly what we're referring to.
dsinger
Gears look good to me
You can see the top of the nut is chewed up that is all the damage I could see. I need to take a better pic
dsinger
The motor is a 115hp Johnson V4 1977
dsinger
Here is a better pic of the pinion and nut
jimmbo
Kind of hard to see details that aren't in focus, but there is a chipped tooth on forward gear(1st pic) and nick to the teeth spiral patern on the reverse gear(2rd pic). The pinion gear looks like it is pitted(3rd pic). Check all bearings and oil pump too.
dsinger
I rebuilt the section of the gears that holds the clutch and rebuilt all the tips and recut. Had the clutch catches built up and I recut them by hand. Another guy in the shop filled all the chips. Have you ever seen this done and if so how did it hold up. X ray showed a less or minus of 9000lbs per mill. in the areas rebuilt. Which was less than that on the section of the pinon that connects to drive shaft.
Xcusme
Two tips: 8)
1. Please resize your pics, you're killing the dial-up folks. Here's a free program to do the resizing.
http://www.virtualzone.de/resizer/
2. On your camera, find the Macro mode (little Tulip or flower icon). You can then take clear close-up shots.
