Cobra 2.3L oil change question, first timer!
Fleetwin
Re: Cobra 2.3L oil change question, first timer!
The engine you have, is a vintage SOHC Ford, that was used in millions of Pintos, Bobcats, Mustang IIs, Ford Ranger pick ups, etc. It is a belt driven SOHC and that timing belt can break, and leave you stranded. Its a good idea to check it and if the belt is looking worn, to replace it. You can't see it without removing the belt cover.
Good advice.
By the way. You can use a (Ford) Motorcraft FL-1A filter. A quality filter at a good price.
That engine is rated at 128 HP. It is not afraid of RPM so don't worry about running it hard.
