Re: Cobra drive "slippage" issues while under way.
Don't you hate it when that stuff happens?
Check to see if it's the prop with the line method across the hub if the lines don't match up after it happens again you need a new prop.
You could try putting a spare prop on and see if that fixs it, and i am hoping it's the prop.
That still don't fix it then it's time for a new cable.
Heres the link to adjusting the cable. Maybe you could just adjust it but when they go out of adjustment USUALLY they are bad.
http://www.hastings.org/~stuart/cobra/kw-shift.html
However i saved the worst for last.
The clutch dog.
Thats the last thing to worry about do everything else and get back to us.
Oh did the temp spike up, did you notice. If your coupler was slipping the temp would go right up. The water pump stopped turning.
If the prop stopped turning then the temp would have stayed the same.
