First time to post- I will try to do it right. I bought a couple of outdrives to rebuild for spares, I was told the both are from V-8's. One says 5.7L on the plate and it has 21:16 gears. No problem. The other I have questions about is what I believe to be a 1987 Cobra outdrive- Model # 983842, Serial # T0449244, with a gear ratio of 21:19. My questions are: Is the year 1987 right? Is this gear ratio for a v-8 or for the 4.3 v-6? If for the 4.3 v-6 can it be used on a v-8 (5.0) with a different prop? What size prop? Can it be used on a 5.7 with a different prop and what size prop? Thank you for your help.
