Yachtsman1304
Thread starter- Joined
- Mar 2, 2009
- 67
Greetings,
I am still trying to get my 4.3 LX/Gen II+ dialed in. I still have some sort of bogging issue....I am leaning towards the coil or something that is affected by high engine heat.
-starts very easily and idles great with no smoke
-after an extended run (10-15 mins), when you come off of plane it will spit and sputter at about 2000 RPM (and the RPMS will drop and act like it wants to stall) and then when you pull the throttle back it will idle back to 700 RPM.
-I can throttle past the sticky area and it will run fine.
-WOT, oil pressure, operating temp and top speed are good. All fuel filters have been changed/inspected.
-the spark plugs have been changed and the new ones have been checked and they look fine...maybe a hair lean.
Now, it SEEMS that if I run the bilge blower that the problem seems much less of an issue. If I run for 20 mins., the engine will completely stall when I come off of plane. So, that makes me think it is a tempature issue in the engine compartment. The vents are on the BACK of the boat so I think the design is bad...but that is just a thought.
Is the problem I am describing sound like a coil issue? I was thinking it was a carb issue for the longest time, but it does not happen all the time....very frustrating.
Sometimes it after I put in the water and I run it, the boat will do "its thing" and then run like freaking top for the rest of the day. Odd odd odd.
Any suggestions will be much appreciated.
Thanks!
Thanks!
