jvaccarino
- Joined
- May 2, 2006
- 123
Had my buddy come over to assist in the troubleshooting of the motor...
Prior to him coming over, I pulled the plug wires to all three cylinders while running (one at a time).. Only the middle cylinder would cause the engine to choke. The top and bottom did not change anything.
I have spark going to all 3 cylinders, I have 120 psi compression, and fuel going to and THRU the carbs..
When we checked the meter on the coil, the middle one was reading 28000 I believe(but had constant voltage)... the other two were jumping from 18-24, to 27000...
Am I looking at BAD coils??
How important is the length of the plug wire? I bought a new wire from discount auto, they only at an 18" long wire..I would assume to takes more energy on a longer run.
Engine was running pretty rough.
other post links
http://forums.iboats.com/showthread.php?t=238697
other post links
