tashasdaddy
- Joined
- Nov 11, 2005
- 51,019
Re: Coil outputs
go to this site, clik on parts, then 1993 then model #, then carborator,
if you pulled # 22 is the low speed jet, # 14 is the high speed jet, behind the bowl drain plug. if you messed with #23 it is set at the factory, if you messed with it there is a special procedure to get it back right.
22 and 14 are the ones to be cleared.
