newtong_ware
- Joined
- Sep 18, 2005
- 59
Here's a question for you guys. Can 1 bad coil cause problems on 2 cylinders?<br />I had some issues getting the motor (115hp johnson 1976) to run right. I wasn't sure if I had a problem with the power pack or the coils. And I still am not real sure.<br /><br />After doing a few things with the electrical and such and rebuilding the carbs I cranked up the boat. I had to work real hard to get it to crank by the way. (This is why I have been working on it in the first place).<br /><br />It just did not seem to be running very good. I checked for spark and found the two port cylinders not getting any spark. I got online and checked on a few things and priced some coils and power packs and went out to check further a few days later.<br /><br />After getting the boat cranked, I checked each plug lead with a timing light while idling.<br /><br />Bottom port cylinder was not showing anything, and I had a good light on other three. I swapped the plug and coil wires between the two port cylinders and now neither would spark.<br />I put them back to the original position and got back to all three except the bottom port cylinder indicating fire.<br />I swapped the bottom port coil for the bottom starboard coil and then both starboard cylinders looked dead and both port fired.<br /><br />Once again, how can one bad coil cause either one or both cylinders in one bank to fail. Is this a coil issue or a power pack/coil combo issue?<br /><br />I thought about just getting all four coils and the power pack and shotgunning the problem, but I had much rather try and understand exactly what is going on as part of the learning process (as well as saving a few dollars).<br /><br />Any ideas?
