Coil question
Robj
I am working on making one 6 hp Johnson from two motors that I have. They are the points ignition vintage. Both engines have no spark, and I think it is odd that I have 4 bad coils (2 per engine). Does anyone know the process for checking these? Want to make sure the coils are shot before I go out and buy new ones.
Thanx for your help and have a great day,
Rob.
tashasdaddy
Re: Coil question
model numbers, and year, not uncommon for those to be bad. they dry out and crack, thus shorting out. picture of them.
Robj
Re: Coil question
Thanx TD. It is probably late 70's vintage. OMC used this coil on many of their engines. Just wanted to know if anyone knew the specs so I can meter them before throwing them away.
Thanx and have a great day,
Rob.
R.Johnson
Re: Coil question
You could check with your dealer to see if he has a coil tester before throwing them away. If they don't have surface cracks', they may be alright.
F_R
Re: Coil question
Using an ohmmeter, check continuity between spark lead and ground wire. Should be several k-ohms.
Then check continuity between points lead and ground lead. Should be Zero ohms with points closed and about an ohm or less with points open. You need a good meter to register an ohm or less.
High voltage leakage such as through cracks or between the secondary windings require a coil tester.
But if they aren't cracked or look like they are covered with drops of dried-up sweat, and pass the ohms test, chances are they are good to go.
Robj
Re: Coil question
Thank you for all your replies. I will check with a meter as F_R suggested.
Have a great day,
Rob.
