tinytanic1
Thread starter- Joined
- Aug 7, 2007
- 13
I have a 1977 120hp Mercruiser. Problem is the coil gets incredibly HOT. I've replaced the resistor wire and coil (along with ign. parts i.e. plugs, points, etc.). I've doublechecked all my wiring throughout engine and control panel accouding to wiring schematics in 140hp service manual. Everything checks out except. I'm getting Battery voltage at '+' end of coil. Should'nt voltage be reduced after going through resistor wire????? I also disconnected the start assist wire leading from starter to coil with same results.
The new resistor wire checks out with 1.5ohms, which is a little less than manual says (1.8ohms), but should still see voltage drop, right?????
I've also replaced ign. switch, solenoid (not solenoid on top of starter, the other 4 post solenoid). I don't have any other ideas???????
