texas_salt
Thread starter- Joined
- Apr 7, 2016
- 42
So, not knowing the engines history, I replaced the entire ignition system, from points to boots. New coils, condensers, wires, points. Gapped .020
Today I installed the final part. The points. Still I had fragmented/no firing on thr top cylinder. Finally I decide it HAS to be the NEW coil. And it was!!!
I put in the old coil, and now its firing on both cylinders.
The issue now is, that top cylinder is misfiring a whole bunch (seeing it with a spark tester). The bottom cylinder glows beautifully at all throttle positions.
So, can misfires be a result of the old coil? When the NEW coil decided to work intermittenly, it didnt seem to misfire, much. With this old coil tho, its all over the place.
Is it a good idea to assume that I just need to swap this non-working NEW coil with another new one (and dump the old one)?
Carb was rebuilt 2 weeks ago. Its crystal clean. Fuel pump should be fine. Like I said, when the new (now not working) coil fired, it didnt seem to misfire all this much.
Thoughts iboaters?
Thoughts iboaters?
