Re: COLD FOUL PLUGS @ 25-1 breakin
One thing I might try on the old Merc 200 with the maker ignition - try swapping out to L77JC4 plugs as they tend to burn a tad hotter and not as prone to fouling. The surface gap lugs are VERY cold plugs. The theory was a cold plug with what, at that time, was a very hot ignition. Didn't always work that way, but when it did, it worked well. Getting the timing nailed is an important part of the set-up, as they must "make" at exactly 180-degrees of each other. Any slop in the magneto plate can mess up that setting and cause misses.<br /><br />- Scott
