win-or-bin
- Joined
- Aug 14, 2011
- 37
Hi all,
i have a Cranchi 21" with a 434a 4.3 v6 (1993) coupled to a DP-C1 outdrive and I have a few questions. I renovated the boat over the winter and had it in the water for the first time yesterday, I am finding the boat hard to start when cold, it will fire immediately off the key run for 3 seconds and then die, after this it will keep dying and I have to have a friend operate the throttle on top of the engine, rev it a few times to warm it up and it idles ok. Just wondered if there is a recommended procedure for this as I go out on my own quite a bit and my arm wont reach from the key to the engine bay
? I am aware that its a carbed engine and will have its own personality!! Also a couple of times out on the water when going from idle to shifting into gear it almost died as well? I have fitted new plugs, drained the fuel tank and system fitted new fuel filter and filled with fresh gas (other than that she went great!)
Also what temp should I see roughly when running? seemed to be running quite cold?
Thanks for any advice
Seumus
Seumus
