Redrig
Master Chief Petty Officer
- Joined
- Oct 13, 2009
- 873
Hello all,
on my 77 OMC 302 with a Holley 2 bbl carb on it.
I have an issue with cold starting, basically it wont start unless I pump the throttle, then it fires right up.
after its warm it will restart with no problems, and the engine idles great once it running. Choke is fully opened after about 5 minutes, its an electric choke model.
Is this a choke issue ? I have the choke set to where it is barely closed when cold. Should I tighten that down a little further ? or could there be other issues.
I would love to be able to start it without priming it from the throttle everytime (less wear & tear on my shift switch)
any ideas?
Thanks in advance
any ideas?
Thanks in advance
