collasped fuel line.
82rude
Why would the line coming from the tank to the fuel pump be collapsed on a merc 470?Had the carb rebuilt last week and my brother ran it up to camp and ran great for about 2 hours and now all it will do is idle .As soon as you give her gas she goes about 100 feet and dies.Pump shows 5 psi according to mechanic .Plugged pick up?
Bt Doctur
have never seen the double wall fuel line collapse.More like a clogged anti-syphon
82rude
Thanks I will pass the info on to my brother.Just blow it out.?Is there a filter to replace or?
82rude
Brother says main line was collapsed .Also where would anti siphon line be?
Bt Doctur
it is a spring loaded check ball , the very first fitting at the tank
82rude
Thankyou very much,sounds right.I also checked other sources and the anti-siphon seems to give the exact symptoms so will check asap.
82rude
Do you replace or fix at the tank on top or inside?
Ayuh,..... It's the hose barb at the tank,....
