Re: colors of fishing line
TwoWatts<br />Fins Prt braid, Cortland Spectron, Cabela's Ripcord, Ripcord SI, and RIpcord SI plus, Power pro, Tuf Line, Tuf Line XP, P-Line Spectrex IV, Stren's Super braid, Bass Pro/Offshore Angler's /spectra. Berkely also makes one I think it is called gorella Bread but not sure. <br /><br />My favorites<br />Cortland's Spectron - Great line been useing for 12 years but hard to find. Internets Captain Mikes site.<br /><br />Cablea's Ripcord Si and Si plus. Good line but high cost.<br /><br />Fins Prt Braid - Good line good price, have IGFA rated lines for setting records.<br /><br />Just got a spool of Stren's Super Bread, and P Line's Spectrex IV. These lines look good and I have a spool of each but have not tested yet. Will test in August week long fishing trip.<br /><br />IMO Power PRO, Tuff Line, Offshore Angler Spectra are good cheap lines but not as refined and smooth as the ones above. <br /><br /><br />If I was to list spiderwire I would list it 2 pages down. To be clear I tested the orginal Spiderwire. The new Spiderwire Stealth I have not tried. The Stealth says Tight-Weave and Teflon.<br />The Spiderwire I tested and several semi pro I fished with tested is the line I do not like. The weave would work loose about 4 inches from the hook, even useing their recommended knots it would come untied. 30 Pound broke while fighting fish in open water twice and leader was 20 lb mono. Drag set at 5 pounds pull at 90 degrees to the rod. Rod a very forgiving 9 foot E-glass rod rated at 15 to 30. Caught hundreds of Salmon on this rod and lost 2 both on spiderwire with fish still 40 yards from the boat in open water. No other line ever broke even when useing a leader of the same weight. If you have a long fight good luck.
