1976 75hp rude just boggs down comp is good 120 on all 3 seems to have good spark i set timing @12degrees with plugs out @wot it calls for 16 and about 7/16 spark gap carbs seem to be clean as i took them apart and cleaned them and done a link and sync even took head off cyls look great put in new ql77v plugs i just got a set of 1981 65hp carbs that are clean as a pin inside and out and all passages are clear i will put them on and try them but it just seems to have no power help please i hope this post is not too long just trying to cover what i done oh and took flywheel off and key is not sheared firing seems to be good also hey i'm begging for help!!!!!
