Commander 3000 help
RinkinIL
So Im a newer boat owner and I'm having some issues.
​​​​I have a commander 3000 classic panel mount that the trim switch went out on. I replaced the switch no issues, but now that everything is back together the handle neutral position is forward about 15 or 20 degrees from where it was at top dead center before I started. The handle only reinstalls on one way, I did not touch a thing on the cables, and other than unbolting the case from the front trim ring to slide the plug for the switch wires in between nothing was taken apart so I'm not sure how this would have happened. Any help would be much appreciated
