Mischief Managed
Thread starter- Joined
- Dec 6, 2005
- 1,928
Encountered a weird problem over the weekend. Went to put the boat in gear to leave the dock and the shift was locked into neutral. Not just more stiff, literally locked solidly in the full upright position as though the red shift lock lever was failing to disengage. Prior to this, it has operated flawlessly for the 14 years I have owned the boat. I was able to get it to work by pushing and pulling the shift lever sideways.
Facts:
1. 7.4 MPI Bravo 3
2. The problem was NOT caused by the red shifter lock lever, it works smoothly and the bottom of it comes completely out of the slot.
3. The throttle-only button allows the shifter to move normally.
4. All the shift and throttle cables are in perfect working order and slide smoothly.
I took the shifter completely apart and all the components looked good. The bushings were fine and all the metal parts had no signs of slop or excess wear. Some of the factory grease from 2000 was a little dried up in places and so I cleaned it all up and re-lubed it.
I could not get the problem to repeat. It does move more smoothly now, but tI'm deeply concerned because I'd hate for it get stuck when docking and shifting is needed to arrest momentum
Any advice would be appreciated. I'm selling the boat this Wednesday and want it to be perfect for the new owner.
Facts:
1. 7.4 MPI Bravo 3
