COMPLETED: Hole on Midsection Repair
Bustedknuckle84
PROBLEM: While reinstalling lower unit i ended up forcing the lower unit to the midsection
Closer look
A look from within the midsection
Start of the repair with thick piece of aluminum
Fitting the 2 sections together
Bustedknuckle84
Re: COMPLETED: Hole on Midsection Repair
More fitting but have to accomidate for the ramp on the right side
Another look
Working on a way to curve the one side up
Starting to fit into place
Bustedknuckle84
Tampering off the front of the 2 pieces
Finished tampering
bolted down
Jb Cold welded into place
Another look
Bustedknuckle84
a look before painting over it
The Finished Project
Painted Flat Black
Works Great
jerryjerry05
Great job.Did you figure out what caused the problem?J
Bustedknuckle84
Thanks Jerry! Yes, i am about 99% sure it was because the shift link coupler was installed the wrong way or upside down. :facepalm: Also i didn't lift up on the prop while reinstalling the lower unit.
bayliner guy1
hey, bud i just did the same stupid thing installing a water pump kit fo the first time ,but i use 2 part epoxy and gave it to coats,but i will be using the sme piece of aluminum like you did because i am afraid of it getting soft in salt water whe i dock it next week.good fix and very ingenuise guy. my other ploblem is after installing my lower unit the prpp only goes counterclockwise an not in reverse when my engine is running,and should"nt the prop stop when in nuetral gear?any help would be appreciated
Bustedknuckle84
thanks for the compliment, sorry for the delay for response, i wanna say the lower unit shift shaft is not set with the shifter used to shift the gears. Try to make sure they are bot hon the same page. the lower shift shaft does rotate, depending on its position determines the gear its in. ill try to find an old post on this and post it, might be your issue here.
