Compression 100 85 100 bad stator
jugheadchamp
I have a 1988 Merc 90 Hp. It left stranded last week on the water. A mechanic said there was no spark and needs a new stator and the compresion was 100 in #1 85 in#2 and 100 in #3 and I needed to rebuild the motor. Can any one tell me if I would be making a bad mistake if I replaced the stator and kept on boating? Thanks for any input you may have.
j_martin
Re: Compression 100 85 100 bad stator
Ain't much goodie left in that motor. It could seriously trash itself any time now.
my 02
John
JB
Hogwash. Compression meets the 15% criterion. A good decarb would probably bring it even closer.
I would fix the ignition and keep on boating.
I hate it when people give doom predictions on engines with plenty of life left in them.
jugheadchamp
The decarb sounds like the ticket, I have never heard of that. I am going to try it. I use my boat at very low rpms, especially when snagging paddlefish last spring, low rpms all day long so decarb won't hurt, and if the motor needs rebuilding I will need the new stator anyway. Thanks.
j_martin
'cept it shoud be running a bit higher than that, assuming the mechanic has a decent compression gauge and we're not talking mountains.
Decarb is worth a shot. If the rings are sticky, it'll loosen em up.
my 02
John
