Intermediate Mariner
Thread starter- Joined
- Apr 24, 2010
- 190
Re: 1962 40 hp Evinrude
Hi,
I have removed powerhead (to repair clevis and bent shift shaft and already had cylinder head off as well to have machined). I had noticed pistons seemed pretty loose. After a few replys and looking around I found that they are pretty loose as a rule, but I should do compression test to be sure on rings.
The question: Can I perform a bench compression test without having to reinstall powerhead back onto exhaust housing as well as reattching starter? Perhaps with an air ratchet on the crankshaft top nut? I would do overhaul if compression fails rather than have to take everything back apart!!
Thanks~
