Re: Compression - can it go back together
I think the Lycoming chart is just adding to confusion. The chart is pulled from some procedure, which may be adding to the confusion (we don't know the context). It appears to be testing some sort of "boost" (like a super charger?) on the engine and what an average psi reading should be, given the conditions of whatever particular test it is. The compression ratio is probably dynamic and only applicable to this Lycoming engine.
BTW: All I know about Lycoming engines are that they used in aircraft.
Outside of all our math, there can be other things that we are not considering. Does the speed of the piston within the bore have an impact? etc.
Anyway, I think I've come to enough of an understanding on the descrepencies between Jasons and our resident experts. Hopefully, this long discussion has been helpful to others.
