Squab
Thread starter- Joined
- Sep 12, 2010
- 140
Here we go, So I finally got a good day to do the compression test and as I pulled out the plugs there was a liquid in cylinder 5& 6. So here is the back story. She ran fine last year and during the winterization process, I pulled the plugs and sprayed wd-40 in each cylinder. I also sprayed fogging spray in the card after the engine was off. A few weeks ago I pulled the carb to make sure all was good and it was. But yesterday there was a good amount of liquid in cylinder 5 &6. Plugs were dirty but showed no signs of rust on inside of cylinder, did have rust on outer bolt where plug meets block. While the Carbs were off I had a towel stuffed in hole and the engine cover was on and the boat was covered. This leads me to believe that was water which settled when I hit it with the Water Displacement - 40.
Engine is a merc 4.3 anyone ?????
