CAPTKEV85
Thread starter- Joined
- Mar 12, 2008
- 229
today i did a compression check on my wonderful 470. i let the engine come up to operating temp. then shut it down and pulled number 1 plug. put tester in cranked engine. psi was 130. check #2 psi 130 checked #3 115 checked #4 130. so obviously #3 is a problem to my overheating and air getting into my cooling system. ohh when i do test run the overflow bottle fills up and spills out. but when she cools it does not suck the antifreeze back in. resulting in now antifreeze in engine. i have put a 1/4 of gallon of coolant in. i think my head is bad. is this possible? is there any other test i can preform? she runs great but when i go full throttle she spits antifreeze everywere. no coolant in oil, or in cylinders. input please:redface:
