compression check
spicerak
do i need to take all plugs out first then check the compression or 1 at a time
ezeke
Re: compression check
Take them all out and record the readings. Be as consistent as possible and use a fully charged battery. If you have a emergency kill switch, you can use it to suppress the spark while you test.
