coin operated
Thread starter- Joined
- Jul 30, 2009
- 35
I have a 1973 Evinrude 115 hp. using JB's method (warming up, pulling all plugs, etc) I get 128 135 120 and 90. Is that too bad to keep using?
The reason I tested it at all is because when I was on the water the other day, at WOT, the motor sounded like it slowed a bit and then it died. I checked my fuel and fuel lines, and didn't see anything. It started up and ran fine to the dock, but I didn't push it back to WOT because I wanted to be sure I made it in. Could this be from the compression? I am sort of a rookie here, but I have replaced the stator, rectifier and power pack on this motor last year. And yes, I changed the impellar, which was harder thatn it should have been, because whoever did it last lost the plastic guide tubes. Any and all advice appreciated.
