compression for 1959 Johnson?
roger56
I will be trying to check the compession on 59 johnson 18hp Tomm. Where can i get a tester and what does it look like? What should the numbers be on the compression Test.
roger56
Re: compression for 1959 Johnson?
thanks i will check it out
roger56
Got a compression checker from son in law Good to go.
boobie
Have both spark plugs out when you check it.
HighTrim
Yeah, and ground the leads. Small possibility of damaging the coils. Only takes a sec to run jumper leads to a bolt head.
JB
Look in the Top Secret File ^^ for procedure.
roger56
Checked compression today on 59 Johnson 90 PSI on both cylinders
boobie
Did you try to fire it up yet ??
tx1961whaler
90 is good. Actually pretty darn good for a pull start motor.
roger56
fired it up motor runs fine on low idle but no high speed. I have another post with history on my progress with this motor
