compression gauge question
spacerust
i wanted to purchase a compression gauge. can i pick one up at the auto store or are there specific ones for outboard motors?
JCF350
Re: compression gauge question
Any will work. Get the screw in type that has the proper size and thread depth (compare with your spark plug), or buy a kit that has changeable ends on it. :)
spacerust
thanks. i will do that.
Ride The Lightning
Hi,
pull off the ignition wires. Actuate at each cylinder the starter a few seconds. The cylinders should not have differences more than 1 bar oder 14,5 psi.
Regards,
Lars
Scaaty
Ground the coil wire if you have electronic ignition..
