Compression Low??
deltaking
89 Johnson 110HP V4: I just checked my compression because could not get the engine to start. At cold engine, it is about 90psi +/- 2 on all cylinders.
1. Is this considered low?
2. If I were to be able to start it and warm it up, would the compression change?
Most people here talk about 100-120psi. Thanks.
tashasdaddy
Re: Compression Low??
what were the other 2 ? no need stroke can be taken cold. the main thing is they are equal with in 10%.
JB
Your compression is fine, king.
Go to the Engine FAQs and do "Outboard won't start" to find out what is wrong.
CharlieB
Some engine series came with only 90 PSI compression.
Search this site for 'Won't start' or engine won't start, you should find a series of directions of how and what to check to lead you to your solution.
