compression numbers please
ronward
does anyone know what comp should be for an 85ESL73M? right bank is 110 both cylinders. left bank is 105 both cylinders. sound like a good motor? has been sitting and probably needs a de-carb to bring up the comp numbers. any takers?
boobie
Re: compression numbers please
For a motor that old they sound okay. Just make sure you do a good decarb on it. I always use BRP engine tuner and have had good luck.
ronward
thanks for the reply. already had the motor running and it runs pretty good.
emdsapmgr
When new, the compression was probably in the 125 range. Your engine should still run with those numbers. Not unusual for compression to vary up to 5 lbs between heads, due to the way they were originally bored at the factory-so that's normal. Agree, a decarb may help the compression.
ronward
Put seafoam in and let sit for a week. Compression now is a solid 125+ on all four. Now to the carbs and pump impeller.
