SeaRayboater95
Thread starter- Joined
- May 30, 2009
- 604
I had a long thread going about hydrolocking and was not getting any responses.
To make a long story short: Hydro locked when cold, pulled sprark plugs, water in number 4 and a little in the pan. Oil level didn't rise but the oil is a little milky.
Pulled manifold and elbow, visually looked fine but have not tested them yet.
Compression test, first number dry, second wet: #2 170/175, #4 160/165, #6 165/170, 165/170.
Does the comp test rule out head gasket. Could the head or block still be cracked.
I have not over heated or froze this engine as it sits in a heated shop all winter. We have been using this boat since April and this condition just started in the last couple of weeks.
I did bend a starter bolt but have had the starter serviced and new bolts.
I'm trying to locate a leak-down tester and may be able to get one tomorrow.
I would really like some answers so I could get this thing running and get a few more trips out of it this year.
I'm thinking I will see if i can get the manifold and elbow preasure tested tomorrow and do a leak dowm test aswell.
I'm confused because there is only water in one cylinder.
Ken
Ken
