Hi all,
Novice here needing some advice(assume I know nothing). I recently purchased a 1979 Sea Ray with a 305 Chevy. I did a compression check to see what I had for an engine today. On the first three cylinders I got readings 65-75 then on the others I got 90 to 110. For grins I went back to the first cylinder and was surprised to get a reading of 90.
Is the fact that I am getting a higher reading on the first cylinder because the motor has had a chance to get some oil on the cylinder walls? My motor won't currently idle(I think it has a tank of old gas). Also, I thought the compression readings should be up near 150. Am I looking at a new motor?
Thank you in advance for the help!
