Compression Question..Evinrude
RobF1970
Can anyone tell me what the ideal compression is for a 1990 evinrude 60 hp?? Maybe minimum/maximum compression data. Thanks
frustratedboater
Re: Compression Question..Evinrude
Usually those engines will hold 115-120 compression normally. I don't have the manuals here, but those numbers are healthy,
~FB~
boobie
The manuals don't have compression specs. As long as there is no more than 15 psi difference between the cyls you're okay.
RobF1970
Thanks fellows..... My compression is ok then.
