Greg O.
Thread starter- Joined
- Jan 9, 2011
- 125
I recently bought a beautiful 1957 10hp Johnson. It was late in October, so I didn't have much time to run it much before winter set in. I was checking the compression on another motor, so I decided to check this 10hp motor. I was shocked it was only 70psi on each cylinder. The motor starts and runs very well. It idles very slow, and has good power. This motor does not seem to have many hours on it judging by the way it looks and for lack of wear on parts like the shift linkage and throttle linkage. Will a de-carburization help the compression much? Or should I re ring the motor, or just de-carb and run it? What is an acceptable compression pressure for this motor? Thanks for your imput.
