I agree as it won't run full throttle at the moment. Ipicked this motor up over the winter as its the same model and only around 100 units off from my old motor and appeared to be in better condition.I swapped it out and started it with muffs but no telltale,removed lower unit and checked the pump,looked good reinstalled.Removed thermostat housing shearing 3 bolts,cleaned and checked thermostat and replaced after cleaning all that pasty white crap out.May have reinstalled pressure relief valve backwards.......Drilled out sheared bolts and installed Helicoils and reassembled.telltale now shows pissing ,but temp alarm still going off.Took out yesterday to see if ran different in real conditions.Bought home ran in container of salt away for an hour and checked compression.Water passages may be fouled with white crud still causing to overheat.When ran on water would not come up full power.
