HVAC Cruiser
- Joined
- Sep 12, 2009
- 1,254
Engine specs.
Chevy 383
Pistons flat top +5cc
heads 76cc
cam Comp cams xtream marine 256
intake Edlelbrock Performer EPS
Carb Edlebrock marine 750 cfm
I am a real upset camper today. I started having engine problems a few weeks ago the carb was acting up, wouldn't take adjustment ( sucking air through the throttle shaft. I ordered a new edelbrock 750 and performer eps manifold. When I took her out she really was not acting right, the sea's were bad so I came back home.
I checked for dead cylinders found #1, 5 & 8 dead as a door nail. Tried swapping out plugs, wires cap to no avail
Yesterday & today I decided to get to the bottom of my problems. I ran a compression test and was shocked at the results
Cyl 1-80#, 3-120#, 5-120#, 7-175#
Cyl 2-150#, 4-110#, 6-130#, 8-100#
I did 2 squirts of oil and redid the test, the pressures really didn't change maybe 2 lbs
There is no oil in the antifreeze (closed cooling) there is no water in the oil.
I am thinking the heads, but every cylinder????? these are the the chevy 76cc castings that are prone to cracking.
If I busted rings I'm thinking I would have metal in the oil , making a racket etc...
Anyone have any thoughts??????
EDIT- Thought about it S@rew it Guess my season is over, I am going to pull it and go through it AGAIN. I might have washed the rings with the bad carb I am getting some blow-by
Chevy 383
heads 76cc
