compression readings
killer14163
i recently replaced my carburetors and intake manifolds on my Volvo penta 4.3l gl twin engines - i was having trouble setting base timing so i took the boat to my mechanic he set the timing then took boat for a lake test. he was unable to get the boat to plain at all on his test. the boat is large it is a regal 2760 express cruiser it has twin 4.3 Volvo's.
i added the bigger carbs to try to get a little more power at the start - but it seems to have done the opposite. the guy is puzzled because after i put the carbs on i set the timing close and took the boat around the lake with no problems -- but it was a little more sluggish then it was previously so i brought it in to make sure the timing is exact. my mechanic set the timing at 1 degree before tdc. i was shooting for 6 degrees when i set it . does it make that much difference that now it wont plain at all?
he did a compression test just to make sure all was good
my starboard motor is new and all had exactly the same 160 to 161 psi
the port engine had cylinder 1 =155 2=159 3=160 here is what puzzles me the other side had a lot more 2= 190 4=185 6=185
he thinks it might be because of the low compression on 1 side.
my boat is prob lay under powered if both engines aren't working efficiently it will not get on plain .
any ideas?
i am going to pick boat up and check timing again myself just to see where it is at.
anything else i should check?
thanks
Tracy
JustJason
Re: compression readings
decarb the port motor and recheck the compression.... 190 is to high.
killer14163
How much bigger are the new carbs? It is fairly easy to "over carberate" these engines if you don't make a change in the cam/intake manifold/exhaust manifold. The fact you had a hard time setting timing properly suggests that your vacuum is all over the place which is tyoical with an over carberation condition.
i went from a holly 2 bbl to a quadrajet 4 bbl carb.
the only diff i can think of is when i set the timing i was looking for 6 degrees advance he went for 1 degree advance
would this make that much difference?
would a bigger carb need to have the timing advanced more?
thanks
Tracy
Ayuh,....
I don't know the Spec for your motors,...
but,... 1? btc sounds Way Too Low...
I'd think 6? btc is more likely right...
killer14163
what do you mean by decarb? remove the carburetor and recheck ? or carbon?
thanks
nevermind stupid question i found out use sea foam
http://video.google.com/videoplay?docid=6187290865726229173
killer14163
Ayuh,...
I Donno,....
I run my Merc 4.3LX at 8?,..... Just because it Detonates at 10?.....
