I checked the compression on the motor I'm currently working on <br /><br />1 125<br />2 128<br />3 120<br />4 125<br /><br />Are these too far apart to be concerned with? (8psi ??)<br />If this is OK, I need to move on to my lack of spark problem. There were a lot of time and weather damaged wires. I had to fix the wire going to the stator and the wires coming out of the amplifier assembly. I'm assuming my fix was not good enough because I am not seeing a spark. Trying to fix those old wires is a royal pain...
