compression #s on '69 85hp Rude
karrick
I checked the compression on the motor I'm currently working on <br /><br />1 125<br />2 128<br />3 120<br />4 125<br /><br />Are these too far apart to be concerned with? (8psi ??)<br />If this is OK, I need to move on to my lack of spark problem. There were a lot of time and weather damaged wires. I had to fix the wire going to the stator and the wires coming out of the amplifier assembly. I'm assuming my fix was not good enough because I am not seeing a spark. Trying to fix those old wires is a royal pain...
JB
Re: compression #s on '69 85hp Rude
Those numbers are just fine, Karrick.<br /><br />Have you tried our SEARCH feature yet? There must be over a hundred posts asking exactly the same question about compression.<br /><br />Spark is a different question. Someone will be along soon with good advice.<br /><br />Good luck. :)
karrick
Yah I've searched before, I just had the other issues I wanted to pick someones brain about...Thanks for the heads up though... :)
