Justinde
Thread starter- Joined
- Dec 11, 2010
- 431
HI All
I did a compression test today ( 125 not revving past about 3800rpm) and the results are as follows- top to bottom:
1: 120 p.s.i
2: 120 p.s.i
3: 130 p.s.i
4: 120 p.s.i
Spark is excellent on all plugs.
I did notice something with the throttle, however.
When the boat was stopped, in the garage, not running etc, I pushed the throttle as far as possible from the remote control, went back to the engine, and the carbies still had at least another 10mm of throttle available. It makes sense to me that full throttle is full throttle, and it appears that my engine is getting to about 3/4 throttle. Before I adjust anything, I wanted to ask you all if this was the ' normal operating range' for the throttle, and will not be effecting my speed at all, or should I get the throttle to open wide up to get the max out of my engine.
You guys are such a great help- thank you in advance.
1: 120 p.s.i
2: 120 p.s.i
3: 130 p.s.i
4: 120 p.s.i
