Compression Test 1988 15 HP johnson
ace1
How much compression should I expect from a rope start engine like this?
5150abf
Re: Compression Test 1988 15 HP johnson
100+ is good and all cylinder within 10%.
Check hot if possible but cold is fine to just always check it the same, either hot or cold.
Some motors run 90 no problem, the big point is that all cylinders are close to the same.
tashasdaddy
remove the plugs, pull 5 times, get readings.
