compression test and timing - 1994 250 hp Johnson
daselbee
Re: compression test and timing - 1994 250 hp Johnson
OK...waiting for updates as they come in.
boobie
I caught the ECT.:laugh:
daselbee
Just for you buddy....just for you.:lol:
adg
OK have tried to get some readings but only succeed for the ohms measurements.
Both the stator and the timer base resistance measurements are within spec, I was able to locate all the wires so that seems ok.
However when trying to measure DVA I guess I did not get much of a reading unfortunately. After reading a bit more carefully I saw this in the CDI troubleshooting procedure:
"A Digital multimeter with peak voltage scale cannot be used without the DVA as the meter is expecting a 60 hertz signal where the outboard can have an equivalent frequency of over 1000 hertz." So guess I will not come any further without the dva adapter.
Guess my old meter would have been good enough with the DVA adapter. Nothing else to do than to get myself such an adapter.
It's a lot to learn :eek: - to be continued.
adg
and here I am back again on the subject; i will try to make my own DVA adapter because they are very expensive here. Can anyone tell me if this way of making one will work for real? Any experience?
thanks,
See youtube link:
adg
thanks,
See youtube link:
