can i get a compression test reading even f my motor wont start. if so how mnay do i ahve to turn the engine over unti i will have an accurate reading. thanx.....TEX
As long as you can pull the starter rope or use the elec starter you can get a reading, do so with all the spark plugs removed.. Each cylinder should be within 10% of each other... Spin her over about 6 to 8 revolutions then you know what you got...
