infoanalysis
Thread starter- Joined
- Dec 11, 2020
- 15
I did a compression test on a Honda bf100 which states in service manual that the psi should be over 150 but when I conducted the test I only get about 60psi
, but consistent between both cylinders
Even after spraying oil in each cylinder, as it may have been standing for some time, it still did about the same.
The engine pulls like it has compression and when I sprayed gas into the carbs it did start up with smoke ( that's probably because of the oil in the cylinders.) When I test compression after the start up still 60 both cylinders. Am I doing something wrong with the compression test? is that typical?
