compression test on a pull start
junior1113
is this possible looking to buy a used 2000 9.9 johnson and anything else to look for besides lower oil, overheat, water flow, and compression also should i have this run in can or is muffs ok 1 more thing how does 575$ sound if all checks out
billy4hp
Re: compression test on a pull start
Absolutely possible....
Remove spark plugs
Install compression tester in desired cylinder
Set no choke, set throttle to wide open (so there is no restriction from the throttle plate)
Recommended that someone holds the ignition kill button if it is momemtary style or set ignition to off so there is no spark
Mark the flywheel and shoot for at least 5 full revolutions, for accuracy try to turn each cylinder tested an equal amount of revolutions
That should do it...
Good luck,
Billy
tashasdaddy
just remove spark plugs, no need for wot, on 2 stroke, 5 good pulls.
junior1113 , don't buy it. just call me and tell me where it is. LOL.
junior1113
what should psi be
