pataterchip
Thread starter- Joined
- Dec 1, 2008
- 19
Warm engine. Ignition disabled (pull kill switch), remove plugs. Install gauge and spin engine 6 or 8 revs. No oil unless you doing further diagnosis of an apparent issue such as low compression on one cylinder. Numbers should ideally be within 10% of each other and over 100# or whatever your service manual indicates. Throttle needs to be full open on a four stroke motor but it doesn't matter on a two-stroke.
I see lots of posts talking about grounding the spark plug wires, is this necessary and if so how exactly would I ground them the boot on mine don't seem to be removeable? I realize this may sound stupid but I can't afford to screw this up. I need to do a compression test but don't want to ruin the ignition coils.
I have a 2001 mercury 60HP 4 stroke 4cylinder bigfoot S/N# OT 294062P.
