Compression test results- WOT issues, 4.3L LX
Baylinerchuck
Problem solved, this thread is closed!!
I'm embarrassed to say that I totally ignored my own philosophy of troubleshooting, namely keep it simple stupid, or kiss. I post this embarrasment in hopes that it could help others out. When I changed the plug wires and cap and rotor out a while back I noticed that the cap had numbers on it referring to the firing order. One set of numbers for standard rotation, one for reverse. Apparently somewhere along the way I managed to swap plug wires for cylinder 2 and 6. In essence I was running on four cylinders.
I made this discovery by pulling one wire at a time off the distributer noting which ones caused a change in idle speed. After getting shocked a few times, (through an insulated pair of pliers and welding gloves), I found no noticeable change when pulling off wires 2 and 6. I swapped those wires since in reverse rotation they are opposite each other in timing order. The engine idle perked up slightly. I knew I was onto something.
I closed everything up and headed to the river. This thing ran like a raped ape. 4800 rpm and about 47 mph. I'm not sure how I could have overlooked something as basic as firing order. The good thing is everything I cleaned or changed thus far needed to be done on a 26 year old motor. I'm not sure what kind of maintenance has been done by the PO, but by the looks of it, not much.
Keep It Simple Stupid, a humbling lesson indeed.
Also, thanks to everyone who posted here trying help.
Scott06
It's always the simple stuff. Much better than I need a new engine...
Rick Stephens
This is why we need to have a beer cooler next to the tool box. Brains need lubrication too.
Baylinerchuck
It appears mine may have been a little too close, lol. I'm very happy it's running good. Now onto addressing the soft spot in the floor over the fuel tank.....oh what lies beneath......
nola mike
Crossed plug wires are the culprit in a surprising number of threads. Silly 8 cylinders...
Baylinerchuck
What makes it more embarrassing is that it's a 6 cylinder....so less cylinders to screw up, lol. I should have used Rick's idea and just claimed I was drunk....lol.
