compression test #'s - good?
rocket350
1. 170
2. 164
3. 159
4. 175
In my mind, it's fine, but I am no expert on these motors. Opinions?
rbh
Re: compression test #'s - good?
if it runs good, you bet.
if you notice it smokes on start up you may want to look at a valve/valve guide job.
rob
thannah84
Those numbers seem ok...Cylinder 3 the rings seem to be getting old but, like stated above, if it runs ok than I wouldn't mess with it.
tawood
A bit of variance there between 3 and 4....in the aircraft bizz (I used to be an a/p mechanic) that would be WAAAAAAY too much, but this isn't an aircraft, it's a boat, and much easier to deal with when the engine "just quits" :eek:
Sooo, I'd say unless you are routinely out 20 miles from shore, I'd agree with the above posts and just use it.
Tim
